Get Result of Operation
Retrieves the final result of a completed Output Creation operation of a specific operation ID.
Request takes no content, and on success returns a response containing either the absolute paths of the final output files produced (multiple spool files) or the content of a final output file (single spool file).
Request
| Method Type: |
POST |
| URI: |
/rest/serverengine/workflow/outputcreation/getResult/{operationId} |
| Content: | – |
| Content Type: |
| Add. Headers: |
Parameters
Path
| Name | Required | Type | Default Value | Description |
| operationId |
Operation ID of Output Creation operation |
Response
Success
| 200 OK |
Absolute Paths of the Output Files or the Output File itself |
application/octet-stream | – | Result of completed operation successfully retrieved |
Error
401 Unauthorized |
application/json |
403 Forbidden |
application/json |
404 Not Found |
application/json |
Operation not found in Server |
