User accounts and security
Connect generally requires only standard Windows user credentials to run, but does require a user with local Windows Administrator when installing the software and when activating the software license. This is to allow read/write access to protected Windows folders and registry entries.
The following links contain the details as to when and where Windows Administrator rights are required:
- Connect Installation: Connect Installation
- Activating Connect: Activating a License
Permissions for PReS Connect Designer
does not require any special permissions to run besides that of a regular program.
It does not require administrative rights and only needs permission to
read/write in any folder where templates
If generating Print output, PReS Connect Designer requires permission on the printer or printer queue to send files.
Permissions for PReS Connect Server
The PReS Connect Server module, used by the Automation module, requires some special permissions to run. These permissions are set during installation, in the Engine Configuration portion of the Installation Wizard, but it can also be configured later by modifying permissions for the service. To do this:
- In Windows, open the Control Panel, Administrative Tools, then Services (this may depend on your operating system).
- Locate the service called Serverengine_UUID , where UUID is a series of characters that depend on the machine where the software is installed.
- Right-click on the service and select Properties.
- In the Connection tab, define the account name and password that the service should use. This can be a local account on the computer or an account on a Windows Domain. The account must have administrative access on the machine. It should also correspond to the user account set up in PReS Worfklow.
