region
The region object defines a sub-section of the input data. Its properties vary according to the type of data.
This object is available when triggering document boundaries On script; see Setting boundaries using JavaScript.
Properties and methods
The following table describes the properties and methods of the region object. This object is available in Boundaries scripts, with all file types.
| Property/method | Description | Return Type |
| found |
Field that contains a boolean value indicating if the last call to |
Boolean |
Read-only object containing the physical coordinates of the region. |
Physical location of the region: x1 (left), y1 (top), x2 (right), y2 (bottom), expressed in characters for a text file or in millimeters for a PDF file. |
Creates a |
A |
