record
The current record in the main data set.
Properties
| Property | Return Type |
| copies | The total number of copies of the current record that must be created. By default, this is 1. This value is used when the record is saved, at the end of the data mapping process for each record. |
| fields | The field values that belong to this record. You can access a specific field value using either a numeric index or the field name, |
index |
The one-based index of this record, or zero if no data is available. |
tables |
The details table that belong to this record. You can access a specific table using a numeric index or the table name. |
Example
See this How-to for an example of how the current record index, and/or the total number of records in the record set, can be displayed in a document: How to get the record index and count.
