sourceRecord
Returns a sourceRecord object containing properties specific to the current source record being processed.
Properties
sourceRecord.properties.property;
| Property | Return Type |
| properties | Returns an array of properties defined in the Preprocessor step with the Record Scope (i.e. dynamically reset with each new record). |
The property, used by the object Source Record, must first be declared in a Preprocessor step:
- Enter the property's name.
- Select Each record from the Scope drop-down list.
- Select a Type for the Property.
