Send (Test) Email
The Send Email dialog is used to generate mail output and send it to each recipient in the Record Set. To open this dialog, select File > Send Email, on the menu.
Note that the subject, recipients etc. must be specified before sending the email; see Email header settings.
For more information about the process of sending out email and the possible settings, see Generating Email output.
Options for this dialog:
  • From group:
    • Name: Enter the name that should appear when sending emails. The name is optional.
    • Email: Enter the email address that will appear as a Sender to the email recipient. A single email address should be written.
  • To group - only when sending a test email:
    • Email address(es): Enter one or more email addresses where the test emails are sent. Multiple emails can be separated by semicolons (;), and can be in the same format as above. Note that every email here will receive all the emails for the record-range below.
    • Use Litmus: Check to also send the emails to the Litmus test email set in the Email Preferences (to go to the Email Preferences, select Window > Preferences, click the arrow next to Email, and then click General). Disabled if no Litmus email is set. Also see this how-to: Test your emails with Litmus.
  • Records group:
    • Select All, or click Selection and enter the range of records that should be sent. Removing the range disables the selection and sends emails to all records in the record set.
  • Attachments:
    • Print context as PDF: If a Print Context exists in the template, its output will be generated and a PDF version of it will be attached to the outgoing email.
    • Web Page context as HTML: If a Web Page Context exists in the template, its output will be generated as a single HTML file with all required resources embedded in the file. This HTML file is then added as an attachment to the outgoing email.
  • Outgoing mail settings:
    • Presets: Use the drop-down to select a preset. These presets are configured in the Email (SMTP) preferences; see Email SMTP settings.
      It is recommended to use an Email Service Provider to get access to tools that give you full control over your mailings, like open rates, click through rates etc. See Using an ESP with PReS Connect.
    • Host: The SMTP server through which the emails are to be sent. Can be a host (mail.domain.com) or an IP address. You can specify a port number as part of the host name, for example: smtp.mandrillapp.com:465.
    • Use authentication: Check if a username and password are needed to send emails through the host.
    • Start TLS: Enabled if authentication is checked. Sends emails through Transport Layer Security (TLS), which is sometimes referred to as SSL.
    • User: Enter the username used to connect to the SMTP server.
    • Password: Enter the password for the above user name.
