MaxiCode
MaxiCode is one of the barcode types that can be added to a template; see Barcode.
Initially the barcode will have the barcode type's default properties. To change those properties, such as the scale and color, open the Barcode properties dialog: right-click the barcode (on the Design tab in the Workspace) and select the barcode type on the shortcut menu.
Barcode properties
This topic lists the properties of the MaxiCode barcode. For the properties of other barcode types, see Barcode type and properties.
Resolution
Select the printer output definition for the barcode (200, 300, 400, 500 or 600 dpi).
Mode
PReS Connect supports several modes; for an explanation of these modes see the MaxiCode page on Wikipedia.
Tilde processing
Check this option to process tilde characters in the data as special characters. (See the Java4less Barcodes Guide to learn what the tilde character can be used for.)
Color
