Royal Mail 4 State (RM4SCC)
Royal Mail 4 State (RM4SCC) is one of the types of barcodes that can be added to a template; see Barcode.
Initially the barcode will have the barcode type's default properties. To change those properties, such as the scale and color, open the Barcode properties dialog: right-click the barcode (on the Design tab in the Workspace) and select the barcode type on the shortcut menu.
Note that this type of barcode doesn't process tilde characters (~) in the data as special characters.
Barcode properties
This topic lists the properties of the barcode types OneCode, KIX Code, Royal Mail 4 State and Australia Post. For the properties of other barcode types, see Barcode type and properties.
Height, width and spacing
  • Bar height: the height of the (shorter) bars.
  • Extended bar height: the total height of the extended bars.
  • Bar width: the width of the bars.
  • Spacing: the distance between the bars.
Scale
  • Proportional: The barcode is stretched up to where it fits either the width or height of the parent box, whichever requires the less stretching.
Add Checksum
When checked, PReS Connect will calculate a Checksum character and add that to the result of the Barcode script. If the value to be encoded is longer than 10 digits, a second check character will be calculated.
Human Readable Message
When this option is checked, PReS Connect shows a human readable text below or above the barcode, as defined using the Text Position, using the specified font and font size. The font size is given in points (pt).
Color
Output format
  • SVG: Vector format. This is smaller in size, but not compatible with Email output.
  • PNG: Binary rasterized format. This is slightly larger than SVG but will display properly in Email output.
