Content elements
Once you have created a template, it can be filled with all kinds of elements, from text to barcodes and from tables to fields on a web form. All types of elements are listed on this page.
There are several ways to insert elements, see Inserting an element.
Each element can have an ID and a class, as well as a number of other properties, depending on the element's type. When an element is selected, its properties can be changed; see Selecting an element, Attributes and Styling and formatting an element.
ID's and classes are particularly useful with regard to variable data (see Personalizing content) and styling (see Styling templates with CSS files).
When you add elements, such as text, images or a table, to the content of a template, you are actually constructing an HTML file. It is possible to edit the source of the HTML file directly in the Designer; see Editing HTML.
Element types
The following types of content can be added to the content of a template:
Most elements are suitable for use in all contexts. There are a few exceptions, however. Forms and Form elements can be used on web pages only, whereas Whitespace elements and Page numbers can only be used in a Print context. Positioned boxes are well suited for Print sections, but are to be avoided in the Email and Web context.
Whether it is best to use a Table or Box to position text, images and other elements, depends on the context in which they are used; see How to position elements for more information.
Editing HTML
To see this, toggle to the Design tab in the workspace. Click anywhere in the content. Take a look at the at the top of the workspace or select the Outline pane. The breadcrumbs show the HTML tag of the clicked element, as well as the HTML tags of other elements to which the clicked element belongs. The clicked element is at the end of the line.
To edit the HTML text directly:
  • In the workspace, toggle to the Source tab.
On this tab you can view and edit the content of the template in the form of plain text with HTML tags (note the angle brackets: <>). You may add and edit the text and the HTML tags, classes, ID’s and other attributes.
To learn more about HTML, see for example https://developer.mozilla.org/en-US/docs/Web/Guide/HTML/Introduction and http://www.w3schools.com/html/default.asp.
Many video courses and hands-on courses about HTML (and CSS) are offered on the Internet as well, some for free. Go, for example, to www.codeschool.com or www.codeacademy.com and look for HTML (and CSS) courses.
Attributes
ID and class
Every element in the content of a template can have an ID and a class. ID's and classes are particularly useful with regard to variable data (see Personalizing content) and styling (see Styling templates with CSS files).
You can specify an ID and/or class when you add the element to the content.
To add an ID and/or class to an element that has already been added to a template, select the element (see Selecting an element) and type an ID and/or a class in the respective fields on the Attributes pane at the top right.
Each ID should be unique. An ID can be used once in each section.
Other attributes
Apart from the ID and class, elements can have a varying number of properties, or 'attributes' as they're called in HTML (see Editing HTML). Which properties an element has, depends on the element itself. An image, for example, has at least four attributes: src (the image's URL), alt (alternate text), width and height. These attributes are visible on the Attributes pane when you click an image in the content.
For each type of element, a small selection of attributes is visible on the Attributes pane at the top right.
In a multilingual template, the proprietary data-translate attribute marks an element for translation. For more information see Translating templates and Tagging elements for translation.
Changing attributes via script
Many attributes can be changed via the user interface. Another way to change attributes is by using a script.
Any of the Script Wizards can produce a script that changes an attribute of an HTML element. Set the Options in the Script Wizard to Attribute, to output the script's results to the value of a specific attribute. See Using the Text Script Wizard.
In code, you can change an element's attribute using the function attr(); see Writing your own scripts and Standard Script API.
To insert an element in a section:
  1. Navigate to where you want to insert the element, using the arrow keys, the mouse, the Breadcrumbs (see Selecting an element) or the Outline pane.
  2. Click the respective toolbar button. Alternatively, click the element on the Insert menu.
  3. Add an ID and/or a class. ID's and classes are particularly useful with regard to variable data (see Personalizing content) and styling (see Styling templates with CSS files).
  4. Do not give an element the ID 'pages' or the class name 'dynamic'. These are reserved words. Using them as an ID or class name leads to undesirable effects.
  5. Use the Location drop-down (if available) to select where to insert the element.
    • At inserts it where the cursor is located in the template.
    • Before element inserts it before the HTML element in which the cursor is currently located. For example if the cursor is within a paragraph, the insertion point will be before the <p> tag.*
    • After start tag inserts it within the current HTML element, at the beginning, just after the start tag.*
    • Before end tag inserts it within the current HTML element, at the end, just before the end tag.*
    • After element inserts it after the element in which the cursor is currently located. For example if the cursor is within a paragraph, the insertion point will be after the end tag of the paragraph (</p>).*
    • Replace inserts it in place of the currently selected element. (This option is not available when inserting content in a .)
    * If the current element is located inside another element, use the Elements drop-down to select which element is used for the insertion location. The list displays every element in the breadcrumbs, from the current selection point down to the root of the body.
    Note: HTML has some restrictions as to which types of elements are allowed as children of other elements. For example, a paragraph element is not allowed to have children that are block level elements - like a Div or a Table. If inserting content at the selected location would produce invalid HTML the final result may be different than expected. For example, when you insert a Div into a paragraph, the paragraph gets split in two. This means you end up with two paragraphs with the Div in between.
For a list of links to the different types of elements, see Element types.
When an element is selected, the Attributes pane shows the attributes of that element, and the Styles pane, next to the Attributes pane, shows which styles are applied to it.
To select an element in the content, you can of course click on it, but this isn't always as easy as it seems, especially when the element has elements inside it.
Click the Edges button on the toolbar t emporarily adds a frame to certain elements on the Design tab. These will not .Print or output.
There are two more ways to select an element in the content:
  • Using the Breadcrumbs at the top of the workspace.
    Breadcrumbs show the HTML tag of the clicked element, as well as the HTML tags of 'parent elements': elements inside of which the clicked element is located. The clicked element is at the end of the line.
    Elements with classes or IDs show these details next to them, for instance div #contents > ol.salesitems > li ~contents.
    Click any of the elements in the Breadcrumbs to select that element. If an element is selected in the Breadcrumbs and the Backspace key is pressed, that element is deleted.
    Click ~contents to select the contents of the element. This way you may, for example, quickly change the text of a hyperlink.
  • Using the Outline pane. You can find this pane next to the Resources pane. It displays a tree view of the elements in the file. Click an element in the tree view to select it.
Deleting an element
To delete an element, select it - as described above - and press the Delete key.
If the deleted element was targeted by a script, you will be asked if you want to delete the script as well.
Scripts are used to personalize templates. To start learning more about scripts, see Personalizing content and Writing your own scripts.
Format elements directly
Images and other graphical elements can be resized by clicking on them and dragging the resize handles. There are toolbar buttons to color, indent or style text. Other toolbar buttons can left-align, right-align, or rotate graphical elements.
The toolbar buttons only represent a selection of the formatting options for each element. There are no toolbar buttons to change an element's margins, or to add a border to it, for example. To access all formatting properties of an element, you have to open the Formatting dialog. There are two ways to do this:
  • Right-click the element and select the type of element on the shortcut menu.
  • Select the element (see Selecting an element) and select the type of element on the Format menu.
See Styling and formatting for more information about the formatting options.
Format elements via Cascading Style Sheets (CSS)
It is highly recommended to use style sheets in templates right from the start. Even more so if the communications are going to be output to different output channels, or if they consist of different sections (for example, a covering letter followed by a policy). Using CSS with templates allows a consistent look and feel to be applied. A style sheet can change the look of multiple elements, making it unnecessary to format each and every element in the template, time and again, when the company's layout preferences change. See Styling templates with CSS files.
