Output Creation Presets Wizard
The File > Print Presets > Output Creation Settings... dialog displays a list of available presets and a summary of their settings. This dialog can be used to create new Presets or to edit and update existing Presets. Presets, however, cannot be deleted or renamed from within this dialog. That must be done manually.
The Presets are all stored as individual files, using the Preset name and a "OL-outputpreset" file extension.
The Presets can be found in the following folder: C:\Users\[UserName]\Connect\workspace\configurations\OutputCreationConfig
Where [UserName] needs to be replaced with your own Windows User Name.
Once saved, Output Presets can be loaded in the Print Wizard, to have the Print Wizard use the selected Output values.
Dialog Interface
                            Configuration Selection section:
- Configuration Name: Use the drop-down to select the presets saved in the default location.
Click the Settings button for more options:
 Click the Reload option to look for new presets.
Click the Import Configuration... option to import one or more Output Presets using a Browse dialog.
If Output Presets of the same name already exist in the Output Presets list, then a choice as to whether to overwrite the existing Preset(s) or not will be provided.
- Properties: Displays a summary of the settings for this Output Creation Preset.
 - Output Type: Displays the print technology used, as defined in the Print options.
 - Inserter: Indicates whether Inserter Marks have been added in the Inserter options dialog. Expand to see which High Capacity Feeder (HCF) model is loaded.
 - Imposition: Indicates if Imposition has been set in the Imposition options dialog. Expand to see the specific imposition settings.
 - Has custom printer settings: Indicates if custom printer settings have been set in the Printer settings dialog. Expand to see the list of settings.
 - Output to: Indicates where the output will be done, either to a file or a printer.
 - Has Custom Finishing: Indicates that the output creation settings contain custom finishing overrides. (See Job Creation Presets Wizard.)
Optional Job Creation Configuration section:
- Configuration Name: Use the drop-down to select a preexisting Job Preset that can then be used as the source of Metadata and Grouping information in the output file mask dialog.
 Click the Reload button to refresh the list of available configurations.
Click Next in this dialog to see the Print options window where output creation settings are selected.
