isRuntime()
The isRuntime() method returns true if the data mapping process is currently running in runtime mode, or false if the configuration is running in debug mode, i.e. in the DataMapper, when designing a data mapping configuration.
The method also returns true if the data mapping configuration is used when printing a document from the Designer, and false when proof printing a document.
This method is available in all scripting environments in the DataMapper.
