Bar Chart Properties dialog
The Bar Chart dialog appears when a Bar Chart object is right-clicked and the Chart... option is clicked. It determines how the Bar Chart is displayed in output and in Preview mode (see Business graphics).
All of the settings in this dialog are equivalent to a property in the amCharts library (see: amCharts' Class Reference). The description of each setting specifies the corresponding property. When you've made a setting, you can also find the property on the Source tab.
General tab
Most settings on the General tab correspond to properties of the AmSerialChart class in the amCharts library; see: AmSerialChart.
General Group:
Display grid above graph: Check to display the grid on top of the bars so that it is always visible. (Equivalent to the
gridAboveGraphs
property; see: gridAboveGraphs.)
Rotate: Check to rotate the chart 90 degrees so that the bars are horizontal starting from the left. (Equivalent to the
rotate
property; see: rotate.)
Stack Series: Check to stack the values in one bar, instead of having one bar per value. (Equivalent to the
stackType
property of the
ValueAxis
; see: stackType.)
Text Group: Determines how text is displayed in labels and legends.
Font: Enter the font-face to use to display text. The font must be installed on the system and defaults to Verdana if the font is not found. (Equivalent to the
fontFamily
property; see: fontFamily.)
Size: Enter the size of the font. Defaults to 11. (Equivalent to the
fontSize
property; see: fontSize.)
Color: Select the color in which to display text: click the colored square to open the Color Picker dialog (Color Picker), or enter a valid hexademical color code (HTML Hex Color) or a valid CSS color (see MDN Web Docs - named color). (Equivalent to the
color
property; see: color.)
3D Group: Creates a 3D effect if both settings in this group are higher than 0.
Value Axis tab
Settings on the Value Axis tab are equivalent to properties of the ValueAxis class in the amCharts library; see: ValueAxis.
Title group:
Label: Enter a label for the value axis (the Y axis, or the X axis if the graph is rotated). (Equivalent to the
title
property; see: title.)
Bold: Check this option if the title should be bold. (Equivalent to the
titleBold
property; see: titleBold.)
Color: The default label color is black. To select a custom color for the label, click the colored square to open the Color Picker dialog (Color Picker), or enter a valid hexademical color code (HTML Hex Color) or a valid CSS color (see MDN Web Docs - named color). (Equivalent to the
titleColor
property; see: titleColor.)
Font Size: Enter a font size for the label. (Equivalent to the
titleFontSize
property; see: titleFontSize.)
Grid group:
Color: Select a color for the grid lines that divide the value axis: click the colored square to open the Color Picker dialog (Color Picker), or enter a valid hexademical color code (HTML Hex Color) or a valid CSS color (see MDN Web Docs - named color). (Equivalent to the
gridColor
property; see: gridColor.)
Opacity: Enter the opacity percentage of the grid. Default is 15%. 100 is fully opaque, 0 is transparent. (Equivalent to the
gridAlpha
property; see: gridAlpha.)
Thickness: Enter a thickness for the grid lines. Default is 1. (Equivalent to the
gridThickness
property; see: gridThickness.)
Tick Length: Length of the tick marks. (Equivalent to the
tickLength
property; see: tickLength.)
Axis group:
Color: Select a color for the value axis: click the colored square to open the Color Picker dialog (Color Picker), or enter a valid hexademical color code(HTML Hex Color) or a valid CSS color (see MDN Web Docs - named color). (Equivalent to the
axisColor
property; see: axisColor.)
Opacity: Enter the opacity in percentage for the axis. 100 is fully opaque, 0 is transparent. Set opacity to 0 to hide the axis. (Equivalent to the
axisAlpha
property of the
ValueAxis
; see: axisAlpha.)
Thickness: Enter the thickness of the axis. (Equivalent to the
axisThickness
property of the
ValueAxis
; see: axisThickness.)
Labels: Check this option to make the labels on the value axis visible. This is often useful in rotated charts. (Equivalent to the
labelsEnabled
property of the
ValueAxis
; see: labelsEnabled.)
Frequency: Defines per how many grid lines a label will be placed. (Equivalent to the
labelFrequency
property of the
ValueAxis
; see: labelFrequency.)
Category Axis tab
Settings on the Category Axis tab correspond to properties of the CategoryAxis class in the amCharts library; see: CategoryAxis.
Title group:
Label: Enter a label for the category axis (the X axis, or the Y axis if the graph is rotated).(Equivalent to the
title
Bold: Check if you want the title to be bold. (Equivalent to the
titleBold
Color: Select a custom color for the label (default is black): click the colored square to open the Color Picker dialog (Color Picker), or enter a valid hexademical color code (HTML Hex Color) or a valid CSS color (see MDN Web Docs - named color). (Equivalent to the
titleColor
Font Size: Enter a font size for the title. (Equivalent to the
titleFontSize
Grid group:
Color: Select a color for the grid lines that divide the category axis: click the colored square to open the Color Picker dialog (Color Picker), or enter a valid hexademical color code (HTML Hex Color) or a valid CSS color (see MDN Web Docs - named color). (Equivalent to the
gridColor
gridAlpha
gridThickness
Position: Specifies if a grid line is placed on the centre of a cell or on the beginning of a cell. (Equivalent to the
gridPosition
property; see: gridPosition.)
Tip:
The position of the ticks (which is Middle by default) does not move with the grid. To change the tick position, add the following to the
categoryAxis
section on the Source tab:
"tickPosition": "start"
tickLength
Tip:
By default, one label per grid line will appear on the Category axis. To change that frequency, add the following to the
categoryAxis
"labelFrequency": "2"
(replace 2 by the desired number of grid lines).
Axis group:
Color: Select a color for the value axis: click the colored square to open the Color Picker dialog (Color Picker), or enter a valid hexademical color code (HTML Hex Color) or a valid CSS color (see MDN Web Docs - named color). (Equivalent to the
axisColor
axisAlpha
property; see: axisAlpha.)
axisThickness
property; see: axisThickness.)
Auto Wrap: Specifies if axis labels (when horizontal) should be wrapped if they don't fit in the allocated space. (Equivalent to the
autoWrap
property; see: autoWrap.)
Graphs tab
Most settings on the Graphs tab correspond to properties of the AmGraph class in the amCharts library; see: AmGraph.
Labels:
Text: Text of the data labels. You can use tags like [[value]], [[description]], [[percents]], or[[category]]. (Equivalent to the
labelText
property; see: labelText.)
Position: Position of the data labels. Possible values are: "bottom", "top", "right", "left", "inside", "middle". (Equivalent to the
labelPosition
property; see: labelPosition.)
Rotation: Rotation of the data labels. Supported notations:
0.0
0.0°
or
0.0 deg
labelRotation
property; see: labelRotation.)
Offset: Vertical offset of the data labels. A positive offset moves the data labels up. A negative value moves them down. (Equivalent to the
labelOffset
property; see: labelOffset.)
Anchor: Select whether the start, middle or end of a data label should be anchored to the bar. This setting moves the labels horizontally. (Equivalent to the
labelAnchor
property; see: labelAnchor.)
Columns:
Width: Specify a bar width between 0 and 1. (This is a relative width, not pixel width). (Equivalent to the
columnWidth
property; see: columnWidth.)
Spacing: The gap in pixels between two columns of the same category. (Equivalent to the
columnSpacing
property of the
AmSerialChart
class; see: columnSpacing.)
Legend tab
Settings on the Legend tab correspond to properties of the AmLegend class in the amCharts library; see: AmLegend.
Show Legend: Specifies if legend is enabled or not. (Equivalent to the
enabled
property; see: enabled.)
Legend Group: Defines how the legends are shown.
Equal label widths: Check so that all labels are of equal width in the Legends box. The Legend's width will accommodate the largest value. (Equivalent to the
equalWidths
property; see: equalWidths.)
Position: Use the drop-down to select where the legend is shown: at the Right, Left, Top or Bottom. (Equivalent to the
position
property; see: position.)
Align: Use the drop-down to select how to align the text in the labels: Left, Middle or Right. (Equivalent to the
align
property; see: align.)
Horizontal Space: Horizontal space between legend items, in pixels. (Equivalent to the
spacing
property; see: spacing.)
Vertical Space: Enter a numerical value (in pixels) to define the vertical space between legend items, and also between the legend border and the first and last legend item. (Equivalent to the
verticalGap
property; see: verticalGap.)
Max Columns: Enter a numerical value to define the maximum number of columns in the legend. If the Legend's position is set to "right" or "left", this is automatically set to 1. (Equivalent to the
maxColumns
property; see: maxColumns.)
Labels Group: Defines if and how labels are shown in the Legend.
Text: Enter the text used to display the labels;
[[title]]
is a variable that will be replaced with the title of the graph. (Equivalent to the
labelText
Markers Group: Defines how the Legend's Markers look. Markers are icons with a color matching the Legend with its corresponding line.
Type: Use the drop-down to select in which shape the Markers are displayed; "none" hides the Markers completely. (Equivalent to the
markerType
property; see: markerType.)
Size: Enter the size (in pixels) for the Markers to be displayed. (Equivalent to the
markerSize
property; see: markerSize.)
Label Gap: Enter the distance (in pixels) between the legend marker and legend text. (Equivalent to the
markerLabelGap
property; see: markerLabelGap.)
Border Width: Use the drop-down to define the thickness of the border added to the Markers. The default value (0) means the line will be a "hairline" (1 px). In case the Marker type is line, this style will be used for the line thickness. (Equivalent to the
markerBorderThickness
property; see: markerBorderThickness.)
Border Color: Color of the Legend's border. Enter a valid hexademical color code (HTML Hex Color) or a valid color name (see MDN Web Docs - named color), or click the colored square to open the Color Picker dialog (Color Picker). (Equivalent to the
markerBorderColor
property; see: markerBorderColor.)
Border Opacity: Enter a numerical value between 0 and 100 to define the opacity (in percentage) of the border. (Equivalent to the
markerBorderAlpha
property; see: markerBorderAlpha. When specified on the Source tab, the value should be between 0 and 1, e.g. 0.8.)
Source tab
The JSON on the Source tab reflects the choices made in the other tabs and, more importantly, provides the possibility to add in any amCharts configuration option that is unavailable via the other tab menus. For more information see: Adding and editing properties manually.
