Locale Settings
The Locale dialog box sets the locale used inside the template. The Locale can affect time, currency output, and other formatting that depends on location and language (see Locale). The default Locale for new templates can be set via the Preferences (Language preferences).
  • Use: Use the drop-down to select how the Locale is set for the current template.
    • System Locale: Select this to use the operating system's locale settings. This is set in the Region settings of the control panel.
    • Explicit Locale: Select this option to specify a static locale which will remain static for this template, whichever server the template is used on.
    • Data Field: Select this to use a data field from the record. The locale will be record-specific in this case.
    • Runtime Parameter: Select this to use the value of a runtime parameter. Runtime parameters are defined in the template, but their value is set at runtime; see Runtime parameters.
  • Locale: Use the drop-down to select a specific locale. Only enabled when Explicit Locale is selected above.
  • Data Field: Use the drop-down to select a field within the current data model that contains the locale.
  • Runtime Parameter: Use the drop-down to select a runtime parameter that will contain the locale.
In case of a data field or runtime parameter, the value must be a string and contain the exact locale to be used, such as "en" or "fr-CA". It cannot be an alias such as "english" or "french". The locale supports both ISO-639-1 alone ("en", "fr", etc) or ISO-639-1 followed by a 2-letter country code ("de-DE", "zh-CN", "fr-CA", "fr-FR", etc).
