Data Matrix settings
A Data Matrix barcode is a high-density, two-dimensional (2D) matrix barcode which supports encoded text, numbers, files and digital data.
Note: In order to create a GS1 compliant Data Matrix barcode, the barcode data must meet the following requirements:
  • The barcode data must start with a leading FNC1 character. Either ~1 or ~d232.
  • The GS1 Application Identifiers (AI) must be used for all data.
    The function code ~1 must be used as field separator for variable length AI elements.
  • Only ASCII characters should be used.
  • General group:
  • Position group:
      The orientations would look like this (using text and a QR barcode as the examples), in a Portrait document:
  • Data Matrix Properties group:
    • Module Width: Specifies the width of the narrow bars. Changing this value to a higher value will generally make the Barcode bigger.
    • Encoding: The data represented in the symbol can be compressed using one of the following algorithms:
      • Auto: Automatically detect the data content and encodes using the most appropriate method. This is the default option.
      • ASCII: is used to encode data that mainly contains ASCII alphanumeric characters (ASCII 0-127). Use where Barcode size is a concern and where the data is alphanumeric.
      • Base 256: used to encode 8-bit values.
      • C40: used for data that mainly consists of numbers and upper-case alphabetic letters.
      • Text: used for data that mainly consists of numbers and lower-case alphabetic letters.
      • None: Does not use any encoding.
    • Format: select the Barcode size format from the drop-down list .
  • Process Tilde:
    Check this option to process tilde characters in the data as special characters.
    Note: with this option checked, any tilde that needs to be included in the output must be escaped by adding another tilde: ~~.
    Note:  The following tilde codes are supported in GS1 DataMatrix barcodes:
    • ~1 = FNC1 character (for GS1 DataMatrix barcodes)
    • ~2 = Structure Append
    • ~3 = Reader programming
    • ~5 = Macro5
    • ~6 = Macro6
    • ~7 = ECI expressions
    • Add button  : Click to display a list of variable data that could be used for generating the Barcode.
  • Condition: Enter the condition which determines whether or not the Barcode will be added to the document at print time. For details on how to create a conditional, see How to Set Conditionals.
    • Add button  : Click to display a list of metadata fields, information fields to add, or common expressions to the condition.
