US Postal Service IMb Settings
US Postal Service Intelligent Mail Barcodes (IMb) are used by the United States postal service. They contain the address of the receiver, encoded in numeric format (0-9).
  • General group:
  • Position group:
      The orientations would look like this (using text and a QR barcode as the examples), in a Portrait document:
  • USPS IMB Properties group:
    • Track height: The height of the small vertical centre tracking bars, in inches (in). Value must be between 0.039 and 0.057 inches.
    • Ascender height: The height of the ascender bar.
      This also determines the height of the descender bar and full height bars, in inches (in). Value must be between 0.082 and 0.111 inches.
    • Module width: Thickness of each bar in the Barcode, in inches (in). Value must be between 0.015 and 0.025 inches.
    • Interchar gap size: The gap between the bars, calculated as a ratio of the module width, where a value of 1.0 equates to a gap width the same as the module width.
      Value must be between 0.012 and 0.04 inches.
      • Print human readable text: Check to add a textual version of the Barcode data.
      • Placement: Use the drop-down to select whether to place the human readable text above or below the Barcode.
      • Font name: Use the drop-down to select the font with which to display the human readable text.
      • Font size: Enter a font size for the human readable text.
  • Process Tilde:
    • Add button  : Click to display a list of variable data that could be used for generating the Barcode.
  • Condition: Enter the condition which determines whether or not the Barcode will be added to the document at print time. For details on how to create a conditional, see How to Set Conditionals.
    • Add button  : Click to display a list of metadata fields, information fields to add, or common expressions to the condition.
