Royal Mail 2D Mailmark
Royal Mail 2D Mailmark is one of the types of barcodes that can be added to a template; see Barcode.
Barcode properties
This topic lists the properties of the barcode type Royal Mail 2D Mailmark. For the properties of other barcode types, see Barcode type and properties.
Module width
The recommendation is to print these barcodes with a module size of 0.5 mm, which equates to 6 dots when printed at 300dpi. The maximum module size for printing is 0.7 mm.
Preferred version
Use the drop-down to select the size of the barcode, in a number of modules. The actual size of the barcode can be 12 mm x 12 mm up to 22.4 mm x 22.4 mm, depending on the preferred version and the module width.
Scale
  • Proportional: The barcode is stretched up to where it fits either the width or height of the parent box, whichever requires the less stretching.
Tilde processing
Color
Output format
