createTmpFile()
Function that creates a file with a unique name in the temporary work folder and returns a file object. This file stores data temporarily in memory or in a buffer. It is used to prevent multiple input/output access to a physical file when writing. In the end, the contents are transferred to a physical file for which only a single input/output access will occur.
In the following script, the contents of the data sample file are copied in uppercase to a temporary file.
Copy
try{
    // Open a reader
    var reader = openTextReader(data.filename);
    // Create a temporary file
    var tmpFile = createTmpFile();
    // Open a writer on the temporary file
    var writer = openTextWriter(tmpFile.getPath());
    try{
        var line = null;
        // Current line
        /* read line by line and readLine will return null at the end of the file */
        while( (line = reader.readLine()) != null ){
            // Edit the line
            line = line.toUpperCase();
            // Write the result in the temporary file
            writer.write(line);
            // add a new line
            writer.newLine();
    finally{
        // Close the writer of the temporary file
        writer.close();
finally{
    // Close the reader
    reader.close();
deleteFile(data.filename);
tmpFile.move(data.filename);
tmpFile.close();
