TextWriter
The TextWriter object, returned by the openTextWriter() function, allows to open a text file, write to it and close it.
Methods
The following table describes the methods of the TextWriter object.
Method Description
close()
Close the stream.
newLine()
Creates a new line in the file.
open(filename)
Creates a new writer on a file to write at the beginning of the file.
Parameters:
  • filename: the path of the file to open
open(inFilename, inEncoding, append)
Creates a new writer on a file.
Parameters:
  • inFileName: the path of the file
  • inEncoding: the encoding to be used when writing to the file
  • append: boolean; true if the data will be written at the end of the file
write(c)
Writes a character in the file
write(value)
Writes a string in the file.
Parameters:
  • value: the string value to write
