Code 128 Settings
Code 128 is a high-density barcode, used for alphanumeric or numeric-only barcodes. It supports all 128 ASCII characters.
  • General group:
  • Position group:
      The orientations would look like this (using text and a QR barcode as the examples), in a Portrait document:
  • Code 128 Properties group:
  • Height: Enter the Barcode height in either metric (cm/mm), inch (in) or point (pt) values.
  • Module Width: Specifies the width of the narrow bars. Changing this value to a higher value will generally make the Barcode bigger.
    • Print human readable text: Check to add a textual version of the Barcode data.
    • Placement: Use the drop-down to select whether to place the human readable text above or below the Barcode.
    • Font name: Use the drop-down to select the font with which to display the human readable text.
    • Font size: Enter a font size for the human readable text.
  • Process Tilde:
    Check this option to process tilde characters in the data as special characters.
    With this option checked, any tilde that needs to be included in the output must be escaped by adding another tilde: ~~.
