GS1-128
GS1-128 is one of the types of barcodes that can be added to a template; see Barcode.
This topic lists the properties and output options of the barcode type GS1-128. For the properties of other barcode types, see Barcode type and properties.
Barcode properties
Module width
Scale
Add Checksum
When checked, PReS Connect will calculate a Checksum character and add that to the result of the Barcode script. If the value to be encoded is longer than 10 digits, a second check character will be calculated.
Tilde processing
Human Readable Message
When this option is checked, PReS Connect shows a human readable text below or above the barcode, as defined using the Text Position, using the specified font and font size. The font size is given in points (pt).
Barcode output
Color
Output format
