MaxiCode
MaxiCode is one of the barcode types that can be added to a template; see Barcode.
This topic lists the properties and output options of the MaxiCode barcode. For the properties of other barcode types, see Barcode type and properties.
Barcode properties
Resolution
Select the printer output definition for the barcode (200, 300, 400, 500 or 600 dpi).
Mode
PReS Connect supports several modes; for an explanation of these modes see the MaxiCode page on Wikipedia.
Tilde processing
Barcode output
Color
