QR Code
A QR Code is one of the types of barcodes that can be added to a template; see Barcode.
Instead of using the Script wizard (see Adding a barcode) you could write your own script to get the data for the QR Code.
This topic lists the properties and output options of the QR barcode. For the properties of other barcode types, see Barcode type and properties.
Barcode properties
Preferred version
There are 40 sizes of QR codes. Select the preferred version for the QR code.
Auto configure
When this option is checked, the barcode generator overwrites the selected Preferred version (the previous selection) and defines the barcode version based upon on the supplied data.
Module size
Enter the size of the square modules in pixels.
Encoding
This option defines the encoding of the barcode. When Auto is selected, the barcode generator determines the encoding based on the supplied string. The other options are:
  • Numeric: 10 bits per 3 digits, with a maximum of 7089 numerical characters.
  • Alphanumeric: 11 bits per 2 characters, with a maximum of 4296 alphanumerical characters.
  • Byte: 8 bits per character, with a maximum of 2953 characters.
  • Kanji: 13 bits per character, with a maximum of 1817 characters.
Extended Channel Interpretation (ECI)
This setting enables data using character sets other than the default set. Select Latin-1, Latin-2, Shift JIS or UTF-8, or select None to disable extended channel interpretation.
Correction level
Part of the robustness of QR codes in the physical environment is their ability to sustain 'damage' and continue to function even when a part of the QR code image is obscured, defaced or removed. A higher correction level duplicates data within the QR Code to that effect, making it larger.
FNC
Use the drop-down to either disable FNC or select a FNC option:
  • No: No FNC option.
  • First: This mode indicator identifies symbols encoding data formatted according to  the UCC/EAN Application Identifiers.
  • Second: This mode indicator identifies symbols formatted in accordance with specific industry or application specifications previously agreed with AIM International. You must then set a value for the Application Indicator property.
Enter the desired Application Indicator value here; either one character (a-z or A-Z) or a 2-digit number (00 - 99).
This option is only enabled when the FNC property is set to Second.
Scale
  • Proportional: The barcode is stretched up to where it fits either the width or height of the parent box, whichever requires the less stretching.
Tilde processing
Barcode output
Color
Output format
Barcode Data
QR Codes can have many different types of data, which determines how the code will be generated. On top of just straightforward data, special data structures are used to trigger actions on the device that reads them. This can include contact cards, phone numbers, URLs, emails, etc.
To learn more about the specifications of the different QR code types, see the ZXing Project barcode contents page.
