Swiss QR Code
The Swiss QR Code is a specific sub-set of QR barcode standards and is one of the several types of barcodes that can be added to a template; see Barcode.
Instead of using the Script wizard (see Adding a barcode) you could write your own script to get the data for the QR Code.
This topic lists the properties and output options available for Swiss QR barcodes. For the properties of other barcode types, see Barcode type and properties.
Barcode properties
Encoding
This option defines the encoding of the barcode. When Auto is selected, the barcode generator determines the encoding based on the supplied string. The other options are:
Numeric: 10 bits per 3 digits, with a maximum of 7089 numerical characters.
Alphanumeric: 11 bits per 2 characters, with a maximum of 4296 alphanumerical characters.
Byte: 8 bits per character, with a maximum of 2953 characters.
Kanji: 13 bits per character, with a maximum of 1817 characters.
FNC
Use the drop-down to either disable FNC or select a FNC option:
No: No FNC option.
First: This mode indicator identifies symbols encoding data formatted according to the UCC/EAN Application Identifiers.
Second: This mode indicator identifies symbols formatted in accordance with specific industry or application specifications previously agreed with AIM International. You must then set a value for the Application Indicator property.
Tilde processing
Barcode output
Color
Output format
SVG: Vector format. This is usually of higher quality, but may take longer to generate and is not compatible with Email output.
PNG: Binary rasterized format. This has a slightly lower quality than SVG but is usually generated faster and will display properly in Email output.
Barcode Data
To learn more about the specifications of the Swiss QR code , please see the Swiss Payments Standard page, or download the barcode specification ig-qr-bill-en.pdf.
Note: The Swiss QR code standard dictates that the barcode dimensions must be 46 mm by 46 mm. Please do not change the barcode dimensions in the <div> entry as this will invalidate the barcode.
