Sample Project: Serving a Web Page
The Serving a Web Page Sample Project creates an OL Connect project that responds to a request by serving a web page. This project extracts data from a parameter in the given URL and shows the value on the web page.
For an introduction to this Sample Project, see Sample Projects overview video on the OL Learn website (start at 12:44) or on Youtube: Serving a Web Page.
Installing the project
To start the Sample Project, select File > New > Sample Projects > Serving a Web Page from the menu. (See also: Serving a Web Page - Sample Project.)
Alternatively, open the Welcome screen, click New at the left, then Project at the right and select the project type.
Tip: Click the
icon at the top right to reopen the Welcome screen.
If the templates and data mapping configurations haven't been sent to Workflow yet, do that first (see Sending files to Workflow).
This requires that the Workflow service is running (see Starting the Workflow service in Workflow's Online Help).
To test the project:
Send the Workflow configuration to the OL Connect Workflow service; see Saving and sending a Workflow Configuration in Workflow's Online Help.
Access the web page by entering the following URL in a browser on the machine that runs Workflow:
http://localhost:9090/hello. -
Follow the instructions on the page to see how values in the URL change the text of the page.
Saving input as sample data
Locate the Workflow configuration in the Configurations\Workflow folder and open it in Connect Workflow.
Select the process.
Enable the Send to Folder step (step 2 in the process).
Send the Workflow configuration to the Workflow service (see Saving and sending a Workflow Configuration) and run it again, with a custom name value.
When you select the file as sample file (on the Debug ribbon), it can be used to debug the process. Note however that the process will not return the web page to a browser, as it wasn't started by a browser.
Tip: The saved file can be used to create a data mapping configuration.
Project details
The web template
The web page is designed in the WEB_HELLO Web Page template. It contains one Web section (see Web pages).
Styling is done via style sheets (see Local formatting versus style sheets). The style rules are in the context_web_styles.css file. Note how they combine the HTML tag, ID and class of elements to select them. (See also: Selectors in OL Connect.)
There are only two scripts in the template, as you can see on the Scripts pane. You can double-click to open them.
- The My name is script looks for an element that has the ID:
hero. Inside that element it looks for the text:@name@and replaces that with either the default name ("John Doe") or the name given in the URL. - The Year script puts the current year in the footer.
For more information about writing scripts, see: Writing your own scripts.
Tip: You don't have to write a script yourself if you just want to insert some data directly into the template. You could simply drag-and-drop the data on the template or use a wizard (see: Variable data in the text).
The project's Workflow configuration, Serving a Web Page.OL-workflow, contains just one process. It is a simple OL Connect Web process (see Web processes with OL Connect tasks).
The NodeJS Server Input task's HTTP action is set to hello. This means that this process will be invoked whenever someone tries to access the Workflow server with this URL: http://{server's address}/hello.
The Delete task is an Output task that does nothing, actually; it doesn't even remove anything. However, this step is useful when running the project step by step in Debug mode. If it wouldn't be followed by another task, the Create Web Content task would not return its output to the Workflow process, where it can be viewed (click View as HTML).
When the browser sends the request to Workflow, the Workflow process starts and puts the request into XML, including the values that were given in the URL. To extract those values from the 'job file' (the XML) the process uses a data mapping configuration, made with the DataMapper: WEB_HELLO Data.
To open the data mapping configuration, select File > Open from the menu and browse to the Configurations\Resources folder.
To create the data mapping configuration, the input data needed to be saved to a file first (see Saving input as sample data).
The sample data file is located in the Configurations\Data folder, but you will also see it when you open the data mapping configuration itself:
For more information about data mapping configurations see The DataMapper.
Customizing the project
Input data
If you want to add other parameters to the URL and use those data in the template, here's how to do that:
Run the project, add more parameters to the URL and let the process save the input data to a file (see Saving input as sample data).
Use the file to create a new data mapping configuration that extracts the additional data. (See Creating a new data mapping configuration.)
Send the new data mapping configuration to Workflow (see Sending files to Workflow).
Open the Workflow configuration, double-click the Execute Data Mapping task to open it and select the new data mapping configuration.
Use the data in the template (see: Personalizing content), send the new template to Workflow and select it in the properties of the Create Web Content task.
Send the Workflow configuration to the server (see Saving and sending a Workflow Configuration in Workflow's Online Help).
Alternatively you could use input data from a Web form. This is demonstrated by another Sample Project: .
Web page
There are countless ways to modify the template. You could add text, images and other elements (see Content elements) and change the layout (see Styling and formatting).
In order to further personalize the web page, open your data mapping configuration (or JSON data, if the input data will be in that format; see Adding JSON sample data) and use the data fields to personalize the page. (See: Personalizing content.)
Finally, in Workflow, adjust the process: double-click the Create Web Content task to open it, and select the new template. This is only necessary when the file name has changed.
Note: If you want the web page to be responsive (have a different layout on screens of different sizes), it is recommended to start a new template with a wizard; see Creating a Web template with a Wizard.
The current Workflow configuration is very simple. In a real-life solution, a process that generates a web page could be part of a larger solution, in which, for example, emails are generated with a link to a personal landing page.
