Fields
A Field is a read-write, user-defined element: a name/value pair, where the name is case-insensitive. It holds custom information about a certain Node in the Metadata structure. Fields are repetitive (i.e. the same field may appear multiple times) and persist through Metadata recreation.
Fields are stored in a collection container object, just like Attributes. As is the case with the different types of Nodes, both collections share a number of methods and properties. The Fields collection however has additional methods to support multiple entries with the same name, which is forbidden with attributes.
Properties
| Name | Type | Description |
Count |
Integer |
Returns the number of elements in the collection. |
Methods
| Name | Return type | Description |
Adds a new element to the collection or overwrites its value. |
Add2(const String Name, const String Value, TAddFlags Flags, Integer Index (optional)) |
Adds a new element with a customizable behavior if the name already exists. |
Clear() |
Deletes all the elements of the collection. |
Integer |
Returns the number of elements with the specified name. |
Deletes the element at the specified index. |
String |
Returns the value of the element stored at the specified index. |
String |
Returns the value of the element of the specified name. |
String |
Returns the value of the n'th element of the specified name. |
String |
Returns the name of the element stored at the specified index. |
