Removing tasks or branches
To remove any task or branch (except Input and Output tasks), use one of the following methods:
- Click on the task or branch you want to delete, go to the Home tab of Connect Workflow Ribbon and click on the Delete button in the Clipboard group.
- Click on the task or branch you want to delete, and press the Delete (or "Del") key on your keyboard.
- Right-click on the task or branch you want to delete, and select Delete from the menu.
When you remove a branch, all the tasks located in that branch are also deleted. When you delete a task, only that task is deleted.
Note: You cannot use the Delete option to remove an input or output task, but you can right-click on them and click Cut instead. This replaces the task with an Unknown task (see Unknown tasks).
To delete the path below a branch crossing (instead of the path to the right of the branch):
- Press Shift+CTRL+Delete.
- From the right-click menu, choose Edit | Delete| Delete Below the Branch.
