Fields
A Field is a read-write, user-defined element: a name/value pair, where the name is case-insensitive. It holds custom information about a certain Node in the Metadata structure. Fields are repetitive (i.e. the same field may appear multiple times) and persist through Metadata recreation.
Fields are stored in a collection container object, just like Attributes. As is the case with the different types of Nodes, both collections share a number of methods and properties. The Fields collection however has additional methods to support multiple entries with the same name, which is forbidden with attributes.
Properties
| Name | Type | Description |
| Count | Integer | Returns the number of elements in the collection. |
Methods
| Name | Return type | Description |
 | Adds a new element to the collection or overwrites its value. | |
| Add2(const String Name, const String Value, TAddFlags Flags, Integer Index (optional)) |
 | Adds a new element with a customizable behavior if the name already exists. |
| Clear() | Deletes all the elements of the collection. | |
| Integer | Returns the number of elements with the specified name. | |
 | Deletes the element at the specified index. | |
| String | Returns the value of the element stored at the specified index. | |
| String | Returns the value of the element of the specified name. | |
| String | Returns the value of the n'th element of the specified name. | |
| String | Returns the name of the element stored at the specified index. |
