M-Files
M-Files is an Enterprise Content Management (ECM) system that is widely used in industry. It provides a metadata driven mechanism for storing, versioning and sharing files across an organization. See https://www.m-files.com for more detail about M-Files.
The Workflow M-Files solution is based on two plugins:
- The M-Files Download plugin for downloading files from an M-Files server.
- The M-Files Upload plugin for uploading files to an M-Files server.
These plugins are not initially installed with Workflow. They are available for download on the . After downloading the .PPK files, you will then need to import them into Workflow yourself.
See Importing a plugin.
Once installed, the M-Files plugins will appear in the Document Management category in the Plug-In Bar.
Note: To be able to use this plugin you need a working M-Files installation and a user account with appropriate permissions.
