HTTP Client Input
HTTP Client Input tasks use the HTTP protocol to issue HTTP GET commands (queries) to HTTP servers. Replies received from the HTTP servers are used as jobfiles and are thus passed on to following tasks.
This initial input task retrieves a single file as specified in the URL option. This file may be of any format, even formats that are not readable by Connect Workflow.
No processing is done by this task. The file retrieved is not changed in any way.
HTTP Client Input will output a single file which was retrieved from the web. Metadata is not generated by this task.
  • URL: Enter the URL of the HTTP server from which the file must be downloaded. Since this is a variable property box, variables may be used, as well as the Get Data and Select Data commands (see Variable task properties). Note that when Connect Workflow connects to a secure page, an SSL (Secure Socket Layer) connection is automatically used.
    Note: The connection to remote HTTPS is done through TLS v1 encryption. Prior to version 2019.2, this was done through SSL v2.3.
    Secure connections (SSL) made with the HTTP Input Client are known to experience issues when connecting to site bindings using the Server Name Indication (SNI). Disabling SNI through the server's site bindings configuration will allow proper SSL connection through the HTTP Input Client.
  • Server requires authentication: Check this option if the HTTP server requires user authentication. This enables the following options.
    • User name: A user name known to the Web server.
    • Password: The password associated with the user name entered above.
  • Custom headers: Some services require additional HTTP headers to be set. To add a custom header, click the + icon; then type the header's name and value.
"Other" Tab
  • Job Information group
  • Backup input files: Check this to save a copy of each data file that is captured by your input. These files are saved in the PReS Workflow Tools working folders under the "Backup" folder.
Job Information definitions
  • %1 - URL address: Contains the full URL that was requested by the task. This includes any GET variables in the URL.
