Input Error Bin
The Input Error Bin task is used specifically and only to create error management processes. These processes do not run on their own but are rather triggered by the On Error tab of tasks in other processes, when that task fails.
This task receives a data file from a task that generated an error. Accompanying this data file is the current Job Infos of the process that triggered the error. This means that this input does not generate its own job infos!
No Metadata is received by this task, and none is generated.
The following error information is generated by the Input Error Bin starting version 7.5, and is accessible throughout the process:
  • %{error.process}: the process name where the error occurred.
  • %{error.tasktype}: the type of the failed task, can be Action, Input, Output, Printer, Comment and Branch.
  • %{error.taskname}: the name of the plugin (the Display Name as seen in the plugin bar).
  • %{error.taskindex}: the index of the task in the process (its position in the process).
  • %{error.errormsg}: the "Message" specified on the OnError tab of the failed task.
  • %{error.errorid}: the error "ID" specified on the OnError tab of the failed task.
No processing is done by this task.
The output of this task is the same as the input - a data file and job infos that are sent from a task that generated an error.
  • The Input Error Bin task does not have any specific properties unique to it, since it only receives input directly from tasks in other processes when an error is generated. For more information, see the chapter on Debugging and error handling.
"Other" Tab
  • Job Information group
  • Backup input files: Check this to save a copy of each data file that is captured by your input. These files are saved in the PReS Workflow Tools working folders under the "Backup" folder.
Job Information definitions
  • This task does not generate any job information.
