WinQueue Input
WinQueue Input tasks capture print jobs received by a Windows printer queue.
Note: Before configuring this task, on the computer running Connect Workflow you will need to create a local printer queue that will be used to receive data files in the form of print jobs. This queue can be shared, so as to be able to receive jobs sent from local as well as remote users.
To ensure that the spooled files created by Connect Workflow remain in the spool folder, the printer queue must be paused.
The WinQueue input regularly polls the selected printer queue for new jobs. When a new job is available, it is captured automatically by this task.
The print job, by default, is in EMF format. If this option is selected, no action is taken on the data file. However, if the RAW format is selected, the job is converted to RAW. Furthermore, if the Create PDF option is selected, the file is converted to a PDF, including metadata.
Either one of 3 formats is output from this task:
- An EMF job format
- A RAW job format
- A PDF with attached metadata.
Note: A PDF that is the output of the WinQueue input task is generally unreadable by the OL Connect Execute Data Mapping task, even if the original document was a PDF. This is because documents are converted to PostScript when printed, and character identity information is usually lost in this process.
A rule of thumb is: if copy-paste from Adobe Acrobat works, the data mapping can also work. However, if the original document is a PDF, an input task that does not require printing is preferred.
- Printer queue: Select the Connect Workflow Printer Queue (the one to which data files are going to be sent; see: Connect Workflow printer queues).
- Printer properties group
- Spool Print Job ins EMF Format (Advanced printing features): Select to create EMF files for Windows Print Converter action tasks (see Action-EMF Converter (Windows Print Converter)). Note that this option must not be selected when capturing generic text type data.
- Spool Print Jobs in RAW Format: Select to output in RAW format, which is the exact data that the computer receives (and is not converted in any way).
- Create PDF (With Metadata): Select to output a PDF.
- Optimize Resulting PDF: The resulting PDF is optimized for size and caching options are enabled. This reduces the size of the PDFs (depending on some factors), but may take more time to output the PDF.
- Include empty files: Check to process empty incoming jobs. The output will be empty, the job is deleted from the print queue, but the job information is available in the process (sending computer and user name, etc).
"Other" Tab
- Job Information group
- Backup input files: Check this to save a copy of each data file that is captured by your input. These files are saved in the PReS Workflow Tools working folders under the "Backup" folder.
Job Information definitions
- %1 - User name: Contains the user name of the user who sent the job to the printer, or the user un which a software sending the job was logged in under.
- %2 - Host computer: Contains the name of the computer from which the job was sent.
- %3 - Printer name: Contains the name of the printer in which the job was received. Is the same for all jobs received on any given printer.
- %4 - Document name: Contains the name of the job as seen in the printer queue from which it is captured. This name is defined by the software that creates the print job.
