2011-03-29
Dismiss this until next updateThis documentation has been updated
The latest version of PrintShop Mail is currently 7.1. This documentation was updated on 2011-03-29 and covers the changes made in this version. If you are still using an older version of PrintShop Mail, you can access its documentation by using the Version: menu at the top-right corner of this screen.
If you wish to upgrade to PrintShop Mail7.1, you can do so via the Upgrade Request page. Note that in order to upgrade, you will need a valid OL Care contract as of 2010-09.
VIPP
VIPP is an acronym for Variable data Intelligent PostScript Printware. The output of this technology consists of a PostScript stream in which reusable images occur only once.
The main difference between VIPP and Optimized PostScript is that images are cached using a proprietary VIPP specific mechanism instead of PostScript forms. The cached images are stored in print ready format.
Print Technology specific settings
  1. Don't spool images (EPS, TIFF, JPEG): This option allows you not to send the recurring images twice to the RIP. The output will only contain references (by filename) to images stored in the project folder.
  2. Project Folder:This option allows you to store recurring images on the fly, and before printing the job, to a "project folder" on the (VIPP enabled) RIP. The folder name can be specified in the Print Dialog.
Encapsulated VIPP supports the following image formats: JPEG, TIFF, EPS and PDF.
Note: This technology requires a RIP that has been enabled for Encapsulated VIPP, and a hardware key that has been upgraded to enable VIPP. For more information on how to upgrade the hardware key, see Upgrading PrintShop Mail.
