Barcode functions and fonts are deprecated in PrintShop Mail 7.0 for Windows. We strongly advise using the Barcode Object instead.
Syntax |
EAN8(Text) |
Description |
Computes an EAN8 barcode. |
Example |
EAN8("9712345") |
Result |
Text |
Any text expression or data field containing a text to be represented by the barcode. |
EAN (European Article Number)
This function prints the variable barcode for the string using the EAN8 standard, which consists of an 7 digit numeric code. To print the barcodes, a special barcode font is needed.
The EAN8 code is similar to the EAN13 barcode. Is used for overseas applications where a country code is required, only five numbers are used.
This barcode is composed of 2 numbers for the country code, 5 numbers for the data characters, and a checksum. The checksum is generated automatically.
