Creating variable text blocks, such as paragraphs and bodies of letters is easier with the TEXT_FILE function. The ability to read .RTF (Rich Text Format) and .TXT files eliminates the need to copy and paste text strings into Expression logic formulas.
Syntax |
TEXT_FILE(Filename) |
Description |
Returns the contents of the TXT or RTF file<Filename> |
Example |
TEXT_FILE("TEST.TXT") |
Filename |
Any text expression or data field containing a text which holds the Filename of TXT or RTF file. |
Allows you to link variable (external) text files in .RTF or .TXT text format to your PrintShop Mail document.
