2011-03-29
Dismiss this until next updateThis documentation has been updated
The latest version of PrintShop Mail is currently 7.1. This documentation was updated on 2011-03-29 and covers the changes made in this version. If you are still using an older version of PrintShop Mail, you can access its documentation by using the Version: menu at the top-right corner of this screen.
If you wish to upgrade to PrintShop Mail7.1, you can do so via the Upgrade Request page. Note that in order to upgrade, you will need a valid OL Care contract as of 2010-09.
Installing PrintShop Mail
Before you start
If you are installing PrintShop Mail on a computer with Windows 2000, XP, 2003 or Vista, make sure you are logged in with full administrative rights before running the installation program.
Installing in Windows
Your installation file may have been delivered digitally or downloaded through our website. In this case, "CD-Rom" refers to the download location of the software and "Setup.exe" refers to a file that may be called "PrintShop Mail Suite 7.exe"
  1. Locate the setup.exe file on the CD-ROM.
  2. Double click this file to start the installation wizard.
    The installer loads the setup (this may take a few minutes).
  3. Select the language you want to use for the installation then click OK.
  4. If your computer is missing prerequisites necessary for PrintShop Mail to be installed, a dialog appears and indicates that they will be installed.
  5. Click Next to download and install the required components.
  6. A warning is displayed indicating that PrintShop Mail Web will be installed with a demo license, if it is installed. Click OK to dismiss the message.
  7. Click Next. The License Agreement page is shown.
  8. When you have read and understood the license agreement, click on I accept the terms of the license agreement. Click Next.
  9. You must accept the terms of the license agreement to continue.
  10. Check the features that you want to install with PrintShop Mail. You cannot unselect PrintShop Mail itself, but can choose not to install its optional components. If you want to install PrintShop Mail Web, check that option. Click Next.
  11. The Destination Folder screen displays the drive and folder where PrintShop Mail will be installed. To install the software elsewhere, click Change... and navigate to the desired folder.
  12. The Program Folder name determines the name that appears in the Start Menu. Keep the default name or change the name as desired, then click Next.
  13. Click Next to start copying the files and install the software. The Setup Wizard starts installing the files.
    When the copying is complete, the final window appears.
    You may check Check for Updates to check for updates after the installation has finished (recommended).
  14. Click Finish to complete the installation of PrintShop Mail.
Installing on Mac OS
PrintShop Mail 5.4 is supported on Macintosh Operating System 10.4.11 and later (including Operating System 10.5).
  1. Locate the PrintShop Mail 5.4.x.dmg file on the CD-ROM or download location.
  2. Double click on this file.
  3. Select the language you want to use for the installation.
  4. Read the license agreement and select " Agree". (If you select " Disagree" , the installation will be canceled).
  5. A window will be displayed " Opening PrintShop Mail 5.4.x.dmg".
  6. You can drag the PrintShop Mail icon to the Applications folder or to any other location on your computer.
