A paragraph is a contiguous range of characters sharing formatting properties such as:
Paragraphs are separated by carriage returns. To start a new paragraph, press ENTER while you are typing text.
To apply alignment to all paragraphs in one or more text objects:
To apply text alignment for a specific paragraph:
To apply text direction.
Tab stops enable you to line up text to the left, right or center.
You can select the following tab stops:
Left Tab |
Text extend to the right from the tab stop. |
Center Tab |
Text is centered at the tab stop. |
Right Tab |
Text extends to the left from the tab stop until the tab's space is filled, and then the text extends to the right. |
To change default tab stop positions:
To set and remove custom tab stop positions, there are two methods available:
Use the Tab Stops dialog box.
Use the horizontal ruler.
To use the Tab Stops dialog box:
PrintShop Mail enables you to control whether formatting marks are hidden or visible in text objects. Formatting marks are newlines, tabs, and spaces. By default, after starting PrintShop Mail, all formatting marks will be hidden.
You can tell PrintShop Mail to show formatting marks by selecting from the View menu Formatting Marks, or by using the button "Show or Hide Formatting Marks" on the View toolbar. This works as a toggle for all text objects.
Formatting marks are just a visual aid, they will not be printed. The marks will scale to the zoom factor of your document, and they will scale to the font size of the surrounding text. They will also be visible while you're editing text.
New line symbol: ¶
Space symbol: .
Tab symbol: (right arrow)
Copy fitting is a feature that will automatically shrink text by reducing the font size, when there is more text than the text box can hold. The font size will be reduced to the font size needed to fit the text in the text box. However, text will not be shrunk beyond the specified minimum font size. When the text needs to be resized, all text will be resized step by step until the text fits or the minimum font size is reached.
When Copy Fitting is enabled, the minimum font size the font can reach is 1; by default the minimum font size is 8. The downsizing of the text in the box stops if one of the containing font sizes reaches the minimum value or if the text fits.
By default the Allow line breaks feature is set to Yes.
When Allow line breaks is set to "Yes", the texts only fit if the individual words are not broken. Text will break on spaces only. It can occur that lines are broken at spaces, but individual words won't be broken.
When Allow line breaks is set to “No”, the text won't break at spaces, only at returns. The text will be downsized until it fits (or gives a warning if it still doesn’t fit)
To change this option:
You can set the space between lines of text by using the Spacing pop up menu on the PrintShop Mail ruler when a text box is in edit mode.
To set the line spacing, double click on the text object and select the text you want to adjust and choose Single, Double, or Other from the Spacing pop up menu.
If you chose Other, choose options for:
Line height: Distance from the top of a line to the top of the line below it.
Inter-line spacing: Distance from the bottom of a line to the top of the line below it.
Paragraph spacing: Distance from the bottom of a paragraph to the top of the first line in the paragraph below it.
You can set margins, paragraph indentation, and text tabs by using the ruler in the edit mode of the text box.
There are four kinds of tab stops and two types of margins, each indicated by a differently shaped icon:
To use the horizontal ruler:
Note: You can also use the horizontal ruler to specify left and right margins. To do this, left click on the position of either the left or right side of the text box and drag the margin to the desired location.
