The Database Toolbar and its button.
Click this button... |
To do this... |
Go to the first record. |
Go to the previous record. |
Go to the next record. |
Go to the last record. |
Go to the current record. |
Display the total number of records in the database. |
Open the Find Record dialog (see below) |
The Total number of records edit box is read-only when a database is open.
When no database is open, you can change the total number of records by entering the desired number of records and pressing Enter.
The Find Record feature is available from the Database menu, the database toolbar or via its shortcut key (CTRL+F). It is only available when a database is open, and will be grayed out otherwise.
The find record dialog appears with the following options:
