Adobe PDF Print Technology allows you to save optimized PDF output files to disk directly from PrintShop Mail. The PDF output files can be used for printing to PostScript level 3 printers and soft proofing when uploading PrintShop Mail documents to PrintShop Web.
When using “Adobe PDF” Print Technology, it is advised to activate Split job option for the best performance.
The Adobe PDF/VT-1 (or VT1) print technology is a VDP type of file, similar to PPML/VDX and VPS files. The PDF/VT-1 format was created by Adobe as an alternative to vendor-specific VDP technologies that were only available on certain printers, instead creating a more "open" format that could be compatible with more printer brands and models.
The main features of Adobe PDF/VT-1 Technology are:
For more information about the PDF/VT technology, see this post on adobe.com's forums.
Print dialog box settings
JobOptions Location
The .joboptions files that are listed in the PDF Settings box can be located in two different folders, depending if they are document-specific or shared between documents.
