7.1
2013-09-23
Verify a Document
Before printing, you can verify your document for possible problems.
To perform document verification
PrintShop Mail performs the following checks at Layout level:
When you select Verify Document from the Layout menu, a progress bar will be displayed, showing the amount of records being checked. The warnings for the whole document will be listed in the Verification Results panel.
Verify document checks the document at two levels:
Verify document will be stopped when 1000 warnings are found or when you press the Cancel button on the progress bar.
Here is a list of a few possible messages:
Error Message Possible Solution
Object is placed beyond the printable area
Move the object on the layout so it is directly on the page
Object is not entirely placed on the layout
Move the object on the layout so it is completely on the page
Text file not found
Verify the expression that creates the filename used by the TEXT_FILE function.
Variable X is not linked to an expression
Check the Variables Panel for any variable that does not have an expression.
Text does not fit in its bounding box
Verify the text box where the error occurs. Either make the text box bigger, or use Text Links to flow the text into another text box.
Image X not found
Verify the file name or expression that calls the images file in your Image box.
Error loading image
Verify that the image you are calling is a valid type supported by PrintShop Mail and that it is not corrupted.
Page number X is invalid; this PDF only contains Y pages
Verify the expression used to choose the page displayed by the PDF, and that the PDF name is the correct one.
Variable X: argument Y is invalid
Verify the expression for the variable.
Variable X: barcode input string Y is invalid
Verify the expression for the barcode object and make sure it corresponds to what the barcode is expecting.
Variable X: date format Y is invalid
Verify the date format for the variable.
X contains at least one TrueType font that is not embedded in the PDF
Recreate the PDF in order to embed all the TrueType fonts.
Variable X: database field Y not found
Verify the database field name in the variable's expression.
You can save any error message in the Verification Results panel or the Warnings panel. To do so, right-click on the message and select Copy. You can then paste it somewher else, for example by emailing it to technical support.
