Favorite Expressions
You can use the Favorites tab in the Expression Editor to save expressions that you use often in your documents. These favorite expressions will be saved in the software preferences, not your document, so they can be used in any documents you create or edit in the future.
To see your existing favorite expressions:
- Open the Expression Editor.
- Go to the Favorites tab.
- The favorites are listed in the box on the left.
To add a new favorite expression:
- Build or write the expression that you want to save as your favorite.
- Copy the expression (select your expression then to CTRL+C on Windows or
+ C on Mac OS)
- Click New.
- Type in a name for the favorite expression in the Name field on the right.
- Paste the expression in the box under the name.
- Click on Save.
To delete an existing expression:
- Click on the name of the favorite expression you want to delete.
- Click on Remove.
