Barcode functions and fonts are deprecated in PrintShop Mail 7.0 for Windows. We strongly advise using the Barcode Object instead.
Syntax |
POSTNET(Text[,Street address number]) |
Description |
Converts a 5 digit (zip code), 9 digit (zip+4 code), or an 11 digit (delivery point barcode) to a valid POSTNET barcode. |
Example |
POSTNET("12345-6534","152 Oxford Street") |
Result |
Text |
Any text expression or data field containing a text to be represented by the barcode. |
Street address number |
Any text expression or data field containing a text to be represented by the barcode. The delivery point number is calculated from this text. |
POSTNET (Postal Numeric Encoding Technique)
This barcode is the special code that is placed on the lower right portion of an envelope.
It is used to speed mail through the postal service (by automated sorting) and get reduced rates.
Start and stop characters are automatically added by PrintShop Mail.
It is recommended that you have an U.S Postal Service Mailpiece Design Analyst review and approve all POSTNET barcodes generated from PrintShop Mail. The Mailpiece Design Analyst is trained to analyze POSTNET barcodes and determine whether or not they meet the U.S Postal Service's technical requirements. Output can be send to them via email (digital file) fax or mail. Point your Web browser to: http://pe.usps.gov/mpdesign/mpdfr_mda_lookup.asp to find the name and contact information for the Mailpiece Design Analyst that is assigned to your geographical area.
