Barcode functions and fonts are deprecated in PrintShop Mail 7.0 for Windows. We strongly advise using the Barcode Object instead.
Syntax |
UPCA(Text, System number) |
Description |
Computes a UPCA barcode |
Example |
UPCA("123456789", 0) |
Result |
Text |
Any text expression or data field containing a text to be represented by the barcode. |
System number |
Numeric expression or data field containing a number which results in a one digit system number (0-9). |
UPC is the standard barcode for items for sale to the public. It is the code seen on items at the local supermarket. UPCA is a fixed length, numeric only barcode.
It contains:
1 digit for a system number
5 digits for the manufacturer number
5 digits for the product number
One checksum digit
The position and value of the digits is standardized by a grocery industry committee. UPCA and UPCE also allow two or five digit supplemental numbers.
UPCA and UPCE codes have an automatic checksum.
Only tags with the system character of 0 can be encoded with this symbology.
