7.1
2013-09-23
Installing a Printer Driver
PrintShop Mail is capable of generating PostScript and non PostScript output.
PostScript output
To generate PostScript output, PrintShop Mail must communicate with a PostScript printer driver. The PrintShop Mail installer installs a PostScript printer which will be used by the application to generate PostScript output.
We recommended that you use either the Adobe or Microsoft printer driver in order to install your own printer.
Adobe PostScript Driver
Printer installation using the Adobe PostScript driver requires the AdobePS installer and a PPD (PostScript Printer Description) file.
For more information about Adobe PostScript Driver, please visit www.adobe.com.
Microsoft PostScript Driver (Windows only)
You can install a printer using the Microsoft PostScript driver with the Add Printer wizard in the Windows Control Panel. The wizard prompts for an INF file containing printer specific information.
Non PostScript output
When you want to print to a non PostScript printer, you just have to select the printer driver for that printer. PrintShop Mail will print through that printer driver non optimized output. Printing and spooling time will be significantly slower compared to other print technologies like Optimized PostScript.
