The Program Settings section applies to your whole PrintShop Mail Design software, not just to this document. When changing these options, they will remain the same between all your documents and templates.
Set this option... |
To do this... |
Variable Markers |
Specify the characters that delimit (enclose) the variables in your text objects. See |
Measurement in |
Select the unit of measurement for PrintShop Mail. |
Items without database |
Specify the total number of records when no database is open. |
Interface language (Windows Only) |
Interface theme (Windows Only) |
Specify the appearance of the application user interface. It is possible to choose from: Classic, Blue, Aqua. |
Panels fade out (Mac OS Only) |
When inactive, panels from the Window menu fade out, moving the mouse over a panel fades it back in. |
To do this... |
Bleed |
Specify color. |
Folding lines |
Specify color. |
Crop marks (Mac OS Only) |
Specify color. |
Printable area |
Specify the order in which the printable areas are drawn, relative to the objects. Top specifies that the areas are always visible, Bottom that they are obscured by objects. |
Guide lines |
Specify the order in which the guide lines are drawn, relative to the objects. Top specifies that the lines are always visible, Bottom that they are obscured by objects. |
Magnetic strength |
Define guide line sensitivity when moving or resizing objects. When the cursor comes within the specified pixel range on either side of a guide line the object snaps to it. |
Generate EPS for vertical text objects(Mac OS Only) |
During printing, PostScript for vertical text object is generated in an alternative way. |
