7.1
2013-01-30
Plain Text field
Plain text fields are the most commonly used input type and are used when you want the user to type letters, numbers, etc. in a form. The height is measured in lines, by default the field allows a single line of input.
A required plain text field showing a description
Web Form Parameters
A plain text field has the following properties:
Default Value
This field type has the following Default Value options:
