Image Collections allows the end user to select an image by browsing a collection of predefined images. The PrintShop Mail document should contain a variable image box, with an expression that refers to a (user input) data field. The Scale property of this box defines how the image is resized relative to the box. Make sure that the Source of the data field is set to User Input. Collections can be assigned to data fields across multiple documents and are managed in the Collection section. Collections examples are: a set of stock images used for backgrounds or a group of company logo variants.
An image collection
When the Field Type is set to Collection the following options are shown:
Required: Defines the collection field as a required field, requiring customers to select an image then.
Separator line: A separator line between two data entry fields. With this option it is possible to arrange web forms that have more complex variable data more logically.
Collection: Select one of the available collections.
