To modify the document Output Options:
Click Publication Types in the Menu bar. The Publication Types overview page is shown.
Click Documents in the side menu.
Select a static document (PDF) from the overview, the Document Summary page is shown.
Click Edit. The Document Output Options screen appears.
The document output options page contains the following sections:
General:
Documents: The Document section lets you replace the High Resolution version of the PDF and optionally add a Low Resolution version. If the View Low Resolution PDF preview is enabled the end user will see this document in the ordering process.
Especially for large PDF documents this options should be enabled and a Low Resolution PDF should be uploaded. Using a Low Resolution PDF will reduce network bandwith and will reduce the respons time of the system.
