To add a new user input field default item:
Click Settings in the Menu bar.
Click User Input Field Defaults in the side menu. The User Input Field Defaults overview page is shown:
The User input field default overview
Click the Add button below the User Input Field Default overview to show the Item Properties page.
The Item Properties page contains the following sections:
Click Save to creat a new user input field default item.
Note: When an existing user input field default is edited the changes are only applied on new user input fields. A designer can change the web form properties for each user input field of each template separately, because when a new user input field is made using a set of defaults the properties of the defaults are copied to the new input field, there is no further link.
