The Export user input field defaults option lets you export a XML file with the user input field defaults from PrintShop Mail Web. To export the user input field default items:
Click Settings in the Menu bar.
Click User Input Field Default in the side menu. The User Input Field Default overview page appears.
Click the Export button below the User Input Field Defaults overview. The Opening window of the web browser appears.
Choose to save the file to disk and open the resulting file (XML format) to read of edit the data with an XML editor.
The Import user input field defaults option lets you import a XML file with user input field defaults on the User Input Field Defaults overview page. To import the XML file:
Click the Import button below the User Input Field Defaults overview. The Import dialog appears.
Click Browse and navigate to the file on your local hard drive.
Check the Remove Existing User Input Field Defaults checkbox to remove the existing user input field defaults from the overview. If the Remove Existing User Input Field Defaults checkbox is not checked existing defaults are maintained. If duplicate user input field defaults are found the user input field defaults are updated based on the data found in the uploaded file.
