7.1
2013-01-30
Modify a role
To modify a role:
  1. Click Settings in the Menu bar.
  2. Click Roles in the side menu. An overview of the available roles is shown.
    The users column of each row represents the numbers of users with that particular role.
  3. Select a role from the overview. The Properties of that role are displayed.
    In the Role Properties screen you see the collapsible sections for which you can define user rights. In each section you can specify whether a user with the selected role may perform a given function or not. The settings for the following sections can be modified.
    If one or all sections are collapsed it is possible to close all sections at once with the Collapse all button. The role properties screen with the collapsible sections is visible than.
Here are the different properties that may be modified in the Role properties:
General
New document
The New document section controles whether users are allowed to see disabled companies, departments, publication types and documents in the New document section of PrintShop Mail Web.
Order Manager
In the Order Manager section each option group is related to a part of the side menu in the Order Manager.
The Access checkbox controls whether the role can act as an Order Manager. When checked, it will give you access to all options for the order manager.
Companies
The Access checkbox controls whether the users in the role can see the Companies tab in the Menu bar. When checked, it will give you access to all options for the companies section.
Users
The Users section defines whether users see the Users tab in the Menu bar. When the Access checkbox is unchecked the other options are not available.
Assign Roles
Some roles allow the end user to manage user accounts (company and department manager). When creating a new account an username and password for that account needs to be specified as wel as a role. The Assign Roles section lets the administrator define which roles the manager can assign when creating and editing accounts. The manager will be able to manage users that have these roles.
Publication Types
In the Publication Types section several blocks can be checked. When the Access checkbox is unchecked all other options are not available.
Collections
The Collection options lets the administrator grant access to the Collection sections and its underlaying features.
PrintShop Mail
In the Printshop Mail section the right to publish documents to PrintShop Mail Web can be defined.
